15.02.2008, 03:35 | #1 | ||
В общем нарыл:
5 Speed Manual Transmission Specifications (7M-GTE) Gearbox model R154 Km/hr per 1000rpm Reverse 3.18 First 3.251 9.6 Second 1.955 16 Third 1.310 24 Fourth 1.000 31.4 Fifth 0.753 41.7 Lubricant Capacity - Gearbox 3 Litres Oil specifications SAE 80W-90 GL4 or 5 Gear Oil Final Drive Ratio 3.727 Differential Code G305 Drive Pinion - Number of teeth 11 Ring Gear - Number of teeth 41 Ring Gear size 200mm Driveshaft Diameter 29.60mm Lubricant Capacity - Differential 1.3 Litres Oil specifications API GL5 Hypoid Non-LSD Gear oil 5 Speed Manual Transmission Specifications (7M-GE) Gearbox model W58 Km/hr per 1000rpm Reverse 3,768 First 3.285 Second 1.894 Third 1.275 Fourth 1.000 Fifth 0.783 Lubricant Capacity - Gearbox 2.6 Litres Oil specifications SAE 75W-90 or 80W-90 GL4 or 5 Gear Oil Final Drive Ratio 4.3 Differential Code Drive Pinion - Number of teeth 10 Ring Gear - Number of teeth 43 Ring Gear size 200mm Driveshaft Diameter 29.60mm Lubricant Capacity - Differential 1.3 Litres Oil specifications API GL5 Hypoid Non-LSD Gear oil ... 6 Speed Manual Transmission Specifications (2JZ-GTE) ГЕТРАГ Gearbox Model V160 (5/93 - 8/97) V161 (9/97 - 07/02) First 3.827 3.724 Second 2.360 2.246 Third 1.685 1.541 Fourth 1.312 1.205 Fifth 1.000 1.000 Sixth 0.793 0.818 Reverse 3.280 3.192 Lubricant Capacity - Gearbox 1.8 Litres - Oil specifications Toyota V160 Gear oil or Castrol Transmax Z Final Drive Ratio 3.266* - - Differential Code B03B (5/93 - 5/96) A03B (5/96 - 7/02) A03B (5/96 - 7/02) Drive Pinion - Number of teeth 15 - 15 Ring Gear - Number of teeth 47 - 47 Ring Gear size 220mm 200mm 200mm Driveshaft Diameter 29.15mm - - Lubricant Capacity - Differential 1.35 Litres - - Oil specifications Standard Non-LSD API GL5 Gear Lube ... взято отсюда: http://www.turbosupras.com/pages/en/.../MA70/ma70.htm ... и здесь: http://www.turbosupras.com/pages/en/...ZA80/jza80.htm
15.02.2008, 04:56 | #2 | ||
Привет. Получается что у гетрага 5 прямая, т.е. 6я такая же как 5 на 154, вывод максималка на этих коробах будет примерно равная, на гетраге укороченны все передачи....
Заморочился на гетраг?
TLCP120, TLC101, JZZ30
15.02.2008, 05:03 | #3 | ||
Smart
не...не по бюджету..да и не интересно.. Интересно w58 усилить или найти-подобрать усиленный кит !!! уж больно у нее передачи хороши! Чуть-чуть короче 154)
15.02.2008, 06:18 | #4 | ||
дороже выйдет.
имхо проще 58на 154 заменить |
15.02.2008, 06:31 | #5 | ||
Светлый
Не совсем.. 58 с прямым выжимом р154 с обратным.. 58 легче 154) ... Не факт, что те прийдет коробка за 50 рублей в полном здравии и не попросит полного рем. комплекта
15.02.2008, 08:04 | #6 | ||
согласен что не факт. но дело канечно твое.
15.02.2008, 08:14 | #7 | ||
То Kind- 154 ставь и не прьсо
15.02.2008, 08:24 | #8 | ||
не хочу 154...мне моя нравится...)..
P.s. Я темку создал для общего развития, что б люди могли посмотреть чем отличаются коробки!)
15.02.2008, 08:25 | #9 | ||
Как только GTE мотор воткнешь да сцепу кинешь со старта, срежет твоя короба зубчики
15.02.2008, 08:28 | #10 | ||
Smart
У Maksimus-NSK чего-то еще не срезало
15.02.2008, 09:29 | #11 | ||
Матор дохлый
Если серьезно, это всего лишь дело времени, в стоке может 58 на gte и будет ходить какое то время, но после хорошего бустапа пистец ей придет в любом случае.... Мы на РБ26тт моторе ставили меху от простого скайлика, ну месяца полтора выдерживает в среднем
15.02.2008, 09:48 | #12 | ||
Smart
ну я б не стал сравнивать надежность тойеты и ниссана... Вопрос еще в том как эксплуатировать 58-ую!
15.02.2008, 11:50 | #13 | ||
последняя повышающая ...
счас почти всегда так ... |
15.02.2008, 17:59 | #14 | ||
может быть не втему но всеж скажите какая коробка механика ставится на двиг 1G-FE, номера какие
15.02.2008, 18:11 | #15 | ||
roomzes
w55 и w57
15.02.2008, 18:17 | #16 | ||
Спасибо,а максимум на какую мощность они расчитаны?
15.02.2008, 18:30 | #17 | ||
kind, поставишь керамику, усиленную корзину и оденешь слики, и помрет 58 коробка
15.02.2008, 18:56 | #18 | ||
Светлый
нах мне керамика и слики? мне достаточно кевлара.... масло погуще + охлаждение коробки! Добавлено спустя 34 секунды: roomzes сил на 200-250 в пиках
16.02.2008, 06:05 | #19 | ||
kind, ну посмотрим что ты скажешь летом на турбомашине на дрэге
16.02.2008, 06:34 | #20 | ||
Светлый
Меня не очень возбуждает ускорение по прямой с целью минимизации времени прохождения строго определенного расстояния Нам бы что-нить по простому...бочком, бочком как говорится
Различие низа 1G-FE и 1G-GZE | yuri | Двигатель | 7 | 21.01.2013 22:58 |
Различие гидрачей | Улиточк@ | Подвеска, рулевое управление и тормозная система | 0 | 25.02.2012 12:53 |
Различие оптики | QWEN | Кузовные детали и дополнительное оборудование | 3 | 11.02.2009 11:07 |
Различие ЗЕРКАЛ?????????? | Jeka_Chaser | Техническое обслуживание и ремонт | 2 | 05.08.2006 08:08 |
Различие между головками твин кам и VVTi | Двигатель | 7 | 25.07.2006 08:33 |
