19.02.2009, 09:15 | #1 | ||
Стырено вот отсюда и переведено гуглом http://ja.wikipedia.org/wiki/????G?????_(2??)
Впринципе все итак понятно. Оказывается 1G-GE на 71 кузове давал 160 кобыл, а на 81м всего 150. Одни и те же двигатели на сараях и марках тоже оказывается имели разную мощность. А 1G-GTE имел аж 4 варианта. Мож кому-то будет интересно 1G-E (U) 1988cc, 2 valve SOHC EFI. M were developed to focus on smaller, lightweight engines new generation to replace the type, M where the evaluation of the less durable than the type. After 1G-GE porting the control system engine used in the model variations and 1G-II evolution type. Specification Reference: 92kW (125ps) / 5400rpm 172N m (17.5kg m) / 4400rpm (Crown GS110 late, GS120 period) 96kW (130ps) / 5400rpm 172N m (17.5kg m) / 4400rpm (Mark 2 Cresta Chaser GX71 SOARER GZ10 late) 77kW (105ps) / 5200rpm 157N m (16.0kg m) / 4000rpm (SOARER GZ20, Crown GS120 late, GS130 early) 1G-GE (U) 1988cc, 4 valve DOHC EFI. Toyota's first 4 valve 6-cylinder DOHC. (3M ~ 6M-2 valve) 1G giving up of parts, in cooperation with the Yamaha 4 valve DOHC become. City Red 2000rpm raises nearly 7700rpm setting. I down substantially from the torque range of rotational and low negative effect of high speed, were the??in the range of low revolution. Specification Reference: 118kW (160ps) / 6400rpm 181N m (18.5kg m) / 5200rpm (Mark2 , Chaser, Cresta GX70 crown S120, SOARER GZ10) 103kW (140ps) / 6200rpm 162N m (16.5kg m) / 4600rpm (SOARER GZ20 1986.1-1986.12 Supra A70 1986.2-1986.12) 103kW (140ps) / 6200rpm 173N m (17.6kg m) / 4000rpm (Mark II, Chaser, Cresta GX70 SOARER late GZ20 1987.1-1988.12 Supra A70 1987.1-1988.8 Crown S130 1987.9-1988.9) Specification Reference: 110kW (150ps) / 6200rpm 182N m (18.6kg m) / 5600rpm (Mark II, Chaser, Cresta GX81 Crown S130 1988.9-1990.8 SOARER GZ20 1989.1-A70 Supra 1988. 1G-GTE (U) Drive twin-turbo twincam Japan's first (GX71-GT Turbo Twin) 1988cc, 4 valve DOHC EFI (INTAKURATABO water-cooled). ?TTA both the response strongly with high output and fitted with a twin-turbo. Corresponding premium later in the value net been tuned and changed to a cooler interface air-cooling from the cooler interface cooled 185PS to 210PS power. Specification Reference: 136kW (185ps) / 6200rpm 235N m (24.0kg m) / 3200rpm (Mark II, Chaser, Cresta GX71) 136kW (185ps) / 6200rpm 240N m (24.5kg m) / 3200rpm (SOARER GZ20 Supra early A70 early) 147kW (200ps) / 6200rpm 275N m (28.0kg m) / 3400rpm (SOARER GZ20 late 1988.1-1988.12) 154kW (210ps) / 6200rpm 275N m (28.0kg m) / 3800rpm (Mark II, Chaser, Cresta GX81 SOARER GZ20 late 1989.1-Supra A70 late) 1G-GZE 1988cc, 4 valve DOHC EFI supercharger. 1G-GTEU and Crown not setting, Mark II3 set models sedan and grade senior brothers. 1G-GE to TORUKUAPPU is contributed, the result upset the balance of fuel economy and power. Specification Reference: 118kW (160ps) / 6000rpm 206N m (21.0kg m) / 4000rpm (Crown GS120 regular gasoline) 125kW (170ps) / 6000rpm 226N m (23.0kg m) / 3600rpm (Mark II GX81 Gasoline Premium) 1G-FE 1988cc, HAIMEKATSUINKAMU. 2 drives only one camshaft that, by consolidation with the gear 2 to run the book. The form of a 4 valve DOHC is a Toyota "TWIN CAM24" expression of using "24VALVE" will be represented. Later BEAMS, VVT-i that are mounted on the vehicle current and sedan crown at the introduction of engine technologies. (2007 repeal.) The sedan and crowns MAIRUDOHAIBURIDDO (THS-M) combines 1G-FE exists. Toyota's former Incidentally 1G in the engine, is also the engine that longevity of the production the most. (1988, 8 Since its debut in March, 20 the annual production. 2008 End of Month]) Specification Reference: 99kW (135ps) / 5600rpm 177N m (18.0kg m) / 4400rpm (Cresta GX90) 103kW (140ps) / 5600rpm 181N m (18.5kg m) / 4400rpm (Mark II, Chaser, Cresta GX100 crown early S150 late 1997.7-1998.8) VVT-i Specifications 118kW (160ps) / 6200rpm 200N m (20.4kg m) / 4400rpm (Mark II GX110 ALTEZZA GXE10) THS-M spec 105kW (143ps) / 5500rpm 196N m (20.0kg m) / 4400rpm (sedan Crown GBS12) 1G-GP 1988cc, 4 valve DOHC LPG version. Specification Reference: 81kW (110ps) / 5600rpm 152N m (15.5kg m) / 2400rpm (S130 taxi Crown) 1G-GPE 1988cc, 4 valve DOHC EFI-LP LPG version. Specification Reference: 70kW (95ps) / 5200rpm 143N m (14.5kg m) / 2400rpm (KURAUNKONFOTO GXS10, Sedan Crown GXS12) December 1995 - February 2001 81kW (110ps), 5600rpm 152N m (15.5kg m) / 2400rpm
1.5JZ/borg warner S366
Нужна инфа по 1,5 JZ | vitaliy20 | Модификация и свап двигателя | 54 | 22.09.2009 13:25 |
Поздравляю всех жителей форума с Старым Новым годом! | Dimon19 | Общение и дискуссии | 20 | 14.01.2009 07:07 |
1G-FE нужна инфа. | Двигатель | 12 | 09.12.2007 09:31 |
