18.10.2006, 23:40 | #1 | ||
коллеги вот что нарыл в интернете, мощностные параметры можно увеличить за счет топливной смеси, что думаете. оригинал тут
http://www.max-boost.co.uk/max-boost/fu ... tm#optimax ацетон в бнзин тут http://pesn.com/2005/03/17/6900069_Acetone/ рецепт Editor's note: I would NOT suggest that a person use the following fuel mixtures without considering the detrimental effects on your engine, vital engine components (O2 sensor, etc), and other potential damage. That said, the information is interesting. Original published in: GS-Xtra 1213 Gornto Road Valdosta, GA 31602 (912) 244-0577 Editor: Richard Lasetter, president Gran Sport Club of America (GSCA) Formula #1 - Toluene R+M/2.........114 Cost...........$2.50/gal Mixtures with 92 Octane Premium 10%...........94.2 Octane 20%...........96.4 Octane 30%...........98.6 Octane Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores. Formula #2 - Xylene R+M/2.........117 Cost...........$2.75/gal Mixtures with 92 Octane Premium 10%...........94.5 Octane 20%...........97.0 Octane 30%...........99.5 Octane Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*. Formula #3 - Methyl-tertiary-butyl-ether (MTBE) R+M/2.........118 Cost...........$3.50/gal Mixtures with 92 Octane Premium 10%...........94.6 Octane 20%...........97.2 Octane 30%...........99.8 Octane Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy. Formula #4 - Methanol or Ethanol R+M/2.........101 Cost...........$0.60 - $1.75/gal Mixtures with 92 Octane Premium 10%...........94.3 Octane (Methanol) 10%...........94.7 Octane (Ethanol) 20%...........Not Recommended Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water. Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol R+M/2.........101 Cost...........$0.60-$1.50/gal Mixtures with 92 Octane Premium 10%...........94.5 Octane 20%...........Not Recommended 30%...........Not Recommended Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol. Sample Mixture To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses. Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal): 100 oz of toluene for octane boost 25 oz of mineral spirits (cleaning agent) 3 oz of transmission fluid (lubricating agent) This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes. --------------------------------------------------------------------------------- |
19.10.2006, 06:44 | #2 | ||
так и вижу: заправки стоят с одним 92-ым и в ряд колонки с бустерами на вкус -- кому метанол, кому толуол.
в обычной жизни этого не купить
19.10.2006, 11:36 | #3 | ||
купить можно без проблем и официально
кселен тут http://www.nevalab.ru/cat2.php?pat=0000 ... 304b8890a0 изопропил тут http://www.biomedica-prague.cz/ru/raw-m ... hp#menthol или прще заехать на бп, а если нужен 101 его что покупать по 2евро |
19.10.2006, 13:37 | #4 | ||
это все разовое. ну там драгерам может пригодится. а в ОБЫЧНОЙ жизни -- заправился и бегом за пузырьком дополнительным? так ведь и не скажешь, что пузырек: 10-15 литров присыпки требуется
если брать про запас -- на кухне хранить или в багажнике? это же все весьма горюче. я это имел ввиду. купить-то в наше время все можно а в http://www.biomedica-prague.cz/ru/raw-m ... hp#menthol че-то одни душистые вещества. мне как раз актуально. всыпал -- и на холодную не бензином воняет, а ментолом каким-нить
19.10.2006, 17:39 | #5 | ||
а есть присадка, шоб клубникой пахло?
20.10.2006, 15:21 | #6 | ||
Vlad73
нет, только с ванилью
JZX110 IR-V Fortuna Пацанчик шел к успеху... фортануло!!! | Sergienko | Мой автомобиль | 198 | 24.10.2011 18:19 |
Топливо | monstor | Двигатель | 2 | 07.04.2010 14:42 |
Топливо 95 или 98? | edxdx2 | Выбор автомобиля | 31 | 27.12.2009 14:30 |
Кто топливо бадяжит | Kalash-AK74 | Двигатель | 5 | 06.10.2007 15:06 |
